Hi
I am using the Encoder view in KMotionCNC. I prefer this view as it relates to the physical position of the table. But when I press the Zero All button or try to set the values nothing happens. Is there a way to reset the values of the encoders displayed?
I also noted that when you zero all the counters and then run a G-Code program when the servos are off, the green display would show a non-zero value about the size of the MaxFollowingError. This value is incorrect as the table did not move. If you then power the servos and run the G-code again, would this value not result in an offset error? Is there a way to correct this error automatically?
Also, if someone would move the machine table manually, the encoder positions would change but the green display remains the same. Would this cause an offset error?
